Flush cutting cedar http://www-.luthiersforum.com/forum/viewtopic.php?f=10101&t=50467 |
Page 1 of 2 |
Author: | SnowManSnow [ Wed Mar 28, 2018 7:36 pm ] |
Post subject: | Flush cutting cedar |
Tomorrow I’ll flush cut my first cedar top. I’m concerned about chip out from the router on the cedar. Is this more common than w Spruce it am I over thinking it? If it is... are there ways to minimize the potential? Here is the body glued up today ![]() Sent from my iPhone using Tapatalk Pro |
Author: | meddlingfool [ Wed Mar 28, 2018 7:47 pm ] |
Post subject: | Re: Flush cutting cedar |
1) do it in stages, that a lot of overlap. Don't try to get it flush on the first pass. 2) follow the climb cut pattern for on the StewMac trade secrets section in on of the binding tuts. This should be followed for all binding routs. 3) some folks like to add a few layers of shellac to harden the wood 4) sharp bit |
Author: | Freeman [ Wed Mar 28, 2018 7:48 pm ] |
Just finished a WRC guitar. Used a sharp new bit for the cuttoff and binding channels, put a coat of shellac on the top, paid attention to the direction of the cuts, all went fine. ![]() Looks like we have similar thoughts about rosettes..... |
Author: | meddlingfool [ Wed Mar 28, 2018 7:51 pm ] |
![]() Red arrows first, second full pass in opposite direction... |
Author: | DennisK [ Wed Mar 28, 2018 8:09 pm ] |
Do it with a chisel. Cedar cuts like butter. |
Author: | SnowManSnow [ Wed Mar 28, 2018 8:36 pm ] |
DennisK wrote: Do it with a chisel. Cedar cuts like butter. That’s what scares me haha Sent from my iPhone using Tapatalk Pro |
Author: | Ken Lewis [ Wed Mar 28, 2018 8:51 pm ] |
I like to have my tops, and backs for that matter, with a lot less overhang before putting the router to it. When you have a big overhang, as you have there, it stands to reason that there's a lot of wood in contact with the cutter, more wood for the cutter to grab. By having a smaller overhang there'a less wood in contact and a better chance for a successful route with no tearout. A sharp cutter is a must. Ken |
Author: | SnowManSnow [ Wed Mar 28, 2018 9:11 pm ] |
Ken Lewis wrote: I like to have my tops, and backs for that matter, with a lot less overhang before putting the router to it. When you have a big overhang, as you have there, it stands to reason that there's a lot of wood in contact with the cutter, more wood for the cutter to grab. By having a smaller overhang there'a less wood in contact and a better chance for a successful route with no tearout. A sharp cutter is a must. Ken I’ll definitely cut some of that down before cutting And I’d never whack that at once. ![]() Sent from my iPhone using Tapatalk Pro |
Author: | Pmaj7 [ Wed Mar 28, 2018 10:14 pm ] |
SnowManSnow wrote: DennisK wrote: Do it with a chisel. Cedar cuts like butter. That’s what scares me haha Sent from my iPhone using Tapatalk Pro |
Author: | ernie [ Thu Mar 29, 2018 7:49 am ] |
cuchillo spanish luthiers knife, or vlnmakers long knife , and traditionally in europe they used knives to cut down the backs and tops,, Works very quickly with a very sharp clean knife . You have to pay attention to the grain direction !!! |
Author: | Woodie G [ Thu Mar 29, 2018 8:05 am ] |
Top woods are so easily carved that we use a shop knife to trim to within 1/2 of the diameter of the bit to be used to flush trim - and usually closer to 1/8"-1/16". Using a razor saw to make a relief cut down into the waist as well as any other location where the blade may follow the grain and raise the potential for a split reduces the tendency of split-prone woods to misbehave. Our preferred shop knife is the Pfeil Brienz large carving knife, which works well for the task (http://www.chippingaway.com; $23 + P&H) If your top or back is fitted and ready to glue to the rim, an angled pencil (i.e. 3/8" stub of carpenter pencil CA'd to popsicle stick at 90 degrees) can be used to update the outline and permit a closer trimming of the top before closing the box. |
Author: | jfmckenna [ Thu Mar 29, 2018 8:20 am ] |
I use a chisel too. Just pay attention to the orientation of the annular rings. When they are straight like in the apex of the curves of the upper and lower bout you have to be real careful. Work it to a point from both directions then just lop the point off. I usually get it close enough that way then just do the bindings. At the tail and head block when you have to cut across the grain just angle the chisel so you make the cedar top a knife edge then remove that. If you go for it all at once you can get tear out even with a sharp chisel. |
Author: | edstrummer [ Thu Mar 29, 2018 8:26 am ] |
I use my belt sander, very carefully, holding tightly, to take excessive overhang down to where I feel more comfortable with router and flush bit. |
Author: | phavriluk [ Thu Mar 29, 2018 9:28 am ] |
I've used my bandsaw to trim back the overhang. After a bunch of masking tape on the sides and the plate being trimmed. A very high tpi count I suspect would be a good idea. Worked for me, but one side at a time after gluing it on. Or I guess that the guitar body could be tilted out of the way if both top and bottom are on, doing one with a tilt and the other flat to the surface. I think no harm would occur if some familiarization cuts were made first, before trimming close to the body. For trimming right up to the body, Ken Cierpolowski (KMG Guitars) suggested using a flap sander in an electric drill held at an angle, after masking the body so no random whacks with the flap wheel will get to the surface. |
Author: | arie [ Thu Mar 29, 2018 10:00 am ] |
grain "awareness" is critical no matter what method you use. FWIW, I use a chisel. a 60 to 80 grit sanding drum about 2~2-1/2" diameter mounted to a drill press or mill is also a pretty safe choice. move down and along the grain not up against it. put the body face down and position the drum roughly in its center. |
Author: | Woodie G [ Thu Mar 29, 2018 10:18 am ] |
Although we usually knife-trim plates for trimming with the router, it's a good place in the order of build to emphasize that the technique called out in the guide is just one of the many approaches. The boss did a very funny demo on trimming plates which I saw the last time our Wednesday PM student did a weekend work session...think frenetic hamster scrambling around a room-sized cage. 1. Draw knife/scraper (mounted in the trojy) 2. Knife/scraper 3. Chisel/scraper 4. Spokeshave (round bottom)/spokeshave (flat bottom)/scraper 5. Block plane/shave/scraper 6. Oscillating spindle sander and disk sander with tables angled 10 degrees/flush trim router 7. 6x48 stationary belt sander/router 8. Rotozip in trim router (leave the plate oversized) |
Author: | Clay S. [ Thu Mar 29, 2018 11:00 am ] |
I climb cut (figure A above) all the way around. It tends to push the router away and takes smaller bites. If there is a lot of overhang I will take light passes (still climb cutting) to get closer to the side. On Cedar I will often skip the "B" rout and just use a block sander to knock off fuzzies and smooth up the edge. It doesn't hurt to run a strip of tape around the sides where the bearing will run - sometimes the bearing will spin and leave a mark if you don't hold it firmly against the side. And always check the tightness of the bearing screw. |
Author: | SnowManSnow [ Thu Mar 29, 2018 11:16 am ] |
Clay S. wrote: I climb cut (figure A above) all the way around. It tends to push the router away and takes smaller bites. If there is a lot of overhang I will take light passes (still climb cutting) to get closer to the side. On Cedar I will often skip the "B" rout and just use a block sander to knock off fuzzies and smooth up the edge. It doesn't hurt to run a strip of tape around the sides where the bearing will run - sometimes the bearing will spin and leave a mark if you don't hold it firmly against the side. And always check the tightness of the bearing screw. I’ve had the problem w the bearing leaving a mark. Would the tape thickness be an issue? Or I guess... just account for it in the bearing size when you cut the channel for binding Sent from my iPhone using Tapatalk Pro |
Author: | George L [ Thu Mar 29, 2018 11:57 am ] |
Good tips above. I use a chisel to trim plates close, then go with the router as described in the Stew-Mac diagram. For binding channels, I score with a gramil before routing. Scratches or indentations from tools can be a problem with cedar. Leaving the top slightly thick can allow for minor imperfections to be removed during final sanding. |
Author: | Colin North [ Thu Mar 29, 2018 1:21 pm ] |
Clay S. wrote: I climb cut (figure A above) all the way around. It tends to push the router away and takes smaller bites. If there is a lot of overhang I will take light passes (still climb cutting) to get closer to the side. On Cedar I will often skip the "B" rout and just use a block sander to knock off fuzzies and smooth up the edge. It doesn't hurt to run a strip of tape around the sides where the bearing will run - sometimes the bearing will spin and leave a mark if you don't hold it firmly against the side. And always check the tightness of the bearing screw. +1 for "A" all the way. Do the same for binding and purfling ledges. Never a lot of overhang as I chisel/spokeshave excess making a saw cut into the waist first. Very sharp cutter should go without saying but is essential. |
Author: | SnowManSnow [ Thu Mar 29, 2018 2:10 pm ] |
Made small cuts all the way. No issues ![]() Sent from my iPhone using Tapatalk Pro |
Author: | Colin North [ Thu Mar 29, 2018 4:20 pm ] |
Author: | George L [ Thu Mar 29, 2018 4:44 pm ] |
That's the way to go. Well done. |
Author: | Terence Kennedy [ Thu Mar 29, 2018 6:42 pm ] |
That’s great. What I have been doing the last few years is putting the guitar upside down on a good sized wood platform clamped to my router table and use a top bearing bit. I think you are pretty safe doing climb cuts all the way taking off small amounts each pass. Finish up with a block sander. So far so good. With cedar I’d protect the top with some paper taped on. I have had no problems with Spruce. You can hold the guitar slightly off the table as you rout. |
Author: | bluescreek [ Fri Mar 30, 2018 6:27 am ] |
Use a good flush trim bit climb cut the bout areas and rout the rest watch your chips |
